Trigger a Layer 2 Tracetree
Use this procedure to trigger a Layer 2 tracetree. Layer 2 tracetree allows a user to trigger a multicast LTM message by specifying the B-VLAN and I-SID. The command allows the user to view a multicast tree on the SPBM B-VLAN from the source node to the destination nodes for a particular I-SID.
  • On the source and destination nodes, you must configure a CFM MD, MA, and MEP.
  • Enable the MEP.
  • Assign a nodal MEP to the B-VLAN.
Trigger a Layer 2 tracetree:
l2 tracetree {<1-4059> <1–16777215> [routernodename WORD<0–255> | <1-4059> <1–16777215>] [mac <0x00:0x00:0x00:0x00:0x00:0x00>}] [priority <0–7>] [source-mode <nodal|smltVirtual>] [ttl—value <1–255>]
Switch:1#l2 tracetree 500 1
Switch:1# l2 tracetree 500 1
Please wait for l2tracetree to complete or press any key to abort
l2tracetree to 53:55:10:00:00:01, vlan 500 i-sid 1 nickname 5.55.10
hops 64
1   Switch-PETER4        00:15:9b:11:33:df -> Switch-MONTI0        00:14:0d:a2:b3:df
2   Switch-MONTI0        00:14:0d:a2:b3:df -> Switch-LEE2          00:15:e8:b8:a3:df
The following table defines parameters for the l2 tracetree command.
Variable
Value
{ <1-4059><1–16777215> routernodename WORD<0–255> | <1-4059><1–16777215> mac <0x00:0x00:0x00:0x00:0x00:0x00>}
  • <1-4059> — Specifies the VLAN ID.
  • <1–16777215> — Specifies the I-SID.
  • WORD<0–255> — Specifies the Router Node Name.
  • <0x00:0x00:0x00:0x00:0x00:0x00> — Specifies the MAC address.
ttl-value <1–255>
Specifies the TTL value. The default is 64.
priority <0–7>
Specifies the priority value. The default is 7.
source-mode<nodal|smltVirtual>
Note:
Exception: smltVirtual is not supported on 5320 Series.
Specifies the source mode.
The default is nodal.
